I have a flag bit variable that is set by an interrupt routine. Then in my main loop the flag is checked like:
adc0_flag = 0; while(1){ if(adc0_flag == 1){ adc0_flag = 0; process_data() } ... }
"call to process_data() was optimized out " Are you sure it's optimisation? Are you sure there isn't some other problem? Have you checked the generated assembler? The code you posted has at least one typo - please cut-and-paste the exact code you are compiling! In the expression
(adc0_flag == 1)
if( adc0_flag ){
I tried a simplified example that would compile and got the following:
line level source 1 bit my_bit; 2 3 4 void main (void) 5 { 6 1 my_bit = 0; 7 1 8 1 while(1) 9 1 { 10 2 if (my_bit == 1) 11 2 { 12 3 my_bit = 0; 13 3 } 14 2 } 15 1 } 16 ASSEMBLY LISTING OF GENERATED OBJECT CODE ; FUNCTION main (BEGIN) ; SOURCE LINE # 4 ; SOURCE LINE # 5 ; SOURCE LINE # 6 0000 C200 R CLR my_bit 0002 ?C0001: ; SOURCE LINE # 8 ; SOURCE LINE # 9 ; SOURCE LINE # 10 0002 3000FD R JNB my_bit,?C0001 ; SOURCE LINE # 11 ; SOURCE LINE # 12 0005 C200 R CLR my_bit ; SOURCE LINE # 13 0007 ?C0003: ; SOURCE LINE # 14 0007 80F9 SJMP ?C0001 0009 ?C0002: ; SOURCE LINE # 15 0009 ?C0004: 0009 22 RET ; FUNCTION main (END)
