/* **************************************************************************************************** * Filename : MAIN.c * Hardware : Philips P89C51RA2BN + M5M81C55P-2 + SN74HC138 * Software : Keil uVision3 (C51 Compiler V7.50) **************************************************************************************************** */ /* ******************************************************************************** * Hardware Schematic Illustration * ----------- ----------- * | | | | * | |/-------------------------------------\| | * | P0|\-------------------------------------/|AD0..AD7 | * | ALE|-------------------------------------->|ALE | * | \RD|-------------------------------------->|\RD | * | \WR|-------------------------------------->|\WR | * | P1.0|-------------------------------------->|RESET | * | | | | * | P89C51RA2 | | M5M81C55 | * | | | | * | P2.0|-------------------------------------->|IO/M | * | | _______ | | * | P2.1|---------->|A Y0|------------------>|\CE | * | P2.2|---------->|B | | | * | | ------|C | | | * | | | | HC138 | | | * | | | 5V|--|G1 | | | * | | | | | | | * | | |------|G2B | | | * | | |------|G2A | | | * |___________| ----- |_______| |___________| * --- * - *------------------------------------------------------------------------------- * External data space design: * I/O space ----- 0x0100 - 0x0105 * Memory space ----- 0x0000 - 0x00ff ******************************************************************************** */ /* ******************************************************************************** * Include Top-level Head File ******************************************************************************** */ #include <reg51f.h> /* Device specific head file */ #include <absacc.h> /* Absolute memory access */ #include "..\..\COMMON\TYPEDEF.h" /* Data type redefinition */ /* ******************************************************************************** * Variables Definition ******************************************************************************** */ sbit RST_81C55 = P1^0; /* ******************************************************************************** * 81C55 I/O Space Definition ******************************************************************************** */ #define INTERNAL_CMD_STAT_81C55 (XBYTE[0x0100]) #define PA_81C55 (XBYTE[0x0101]) #define PB_81C55 (XBYTE[0x0102]) #define PC_81C55 (XBYTE[0x0103]) #define TIMER_LSB_81C55 (XBYTE[0x0104]) #define TIMER_MSB_81C55 (XBYTE[0x0105]) /* ******************************************************************************** * Functions Declaration ******************************************************************************** */ extern void TimeDly (INT16U); /* ******************************************************************************** * Main Function ******************************************************************************** */ void main (void) { INT8U i; RST_81C55 = 1; TimeDly(5); RST_81C55 = 0; AUXR |= 0x02; /* Enable off-chip memory access */ /* If target device is standard 89C52, comment out the line above */ /*----- Init 81C55 -----*/ INTERNAL_CMD_STAT_81C55 = 0x01; /* Set 81C55 PA output and PB input */ for (i = 0; i < 3; i++) { PA_81C55 = 0xff; TimeDly(1000); PA_81C55 = 0x00; TimeDly(1000); }; /*----- Disassembly code of bold source code above -----*/ C:0x0011 900100 MOV DPTR,#0x0100 C:0x0014 7401 MOV A,#0x01 C:0x0016 F0 MOVX @DPTR,A 116: for (i = 0; i < 3; i++) { C:0x0017 E4 CLR A C:0x0018 F508 MOV 0x08,A 117: PA_81C55 = 0xff; C:0x001A 74FF MOV A,#0xFF why set ACC 0xff, not the external data space 0x0101 118: TimeDly(1000); C:0x001C 120035 LCALL L?0015(C:0035) 119: PA_81C55 = 0x00; C:0x001F E4 CLR A 120: TimeDly(1000); C:0x0020 120035 LCALL L?0015(C:0035) while (1) { PA_81C55 = PB_81C55; TimeDly(1000); } }
Take a look at where this call goes: LCALL L?0015(C:0035) If the optimiser has been up to its tricks you may find the MOVX lurking there.
Thanks a lot to Stefan Duncanson! I found the lurking MOVX
