Union float return
Float_Read(ptr)
/*Value to be stored to EEPROM */
char xdata *ptr;
union
/* UNION to access the bytes of int */
float i;
char split[4];
}data_trans;
data_trans.split[0] = Read_EEPROM(ptr);
data_trans.split[1] = Read_EEPROM(ptr+1);
data_trans.split[2] = Read_EEPROM(ptr+2);
data_trans.split[3] = Read_EEPROM(ptr+3);
printf("Float in Function=%\n",data_trans.i);
return (data_trans.i);
when the function return the float then its zero but the value of float in same function is right,
Is it any problem with return statment?
