Memory dump
I just wrote a simple memory dump routine declared as follows:
void hexdump(U16 start_address, U16 count, bit code_memory);
The idea is to use <code_memory> to select between dumping from XRAM (=0) or code memory (=1).
Inside the routine two pointers are declared:
U8 xdata *xram_pointer;
U8 code *code_pointer;
And initialized (could be done in one shot):
xram_pointer = (U8 xdata *) start_address;
code_pointer = (U8 code *) start_address;
With this in place the output look decides which pointer to use based on <code_memory>, builds the strings using sprintf, and outputs with printf one line at a time.
A couple of questions:
1- "U16 start_address" is this the best way to declare this argument?
2- Is there a way to do this using a single pointer (or "start_address") within the function?
Maybe, define a void pointer and then cast it into either XRAM or code?
Thanks.
  • You really need to consult the manual on the topic of generic pointers.
  • Fair enough. I did read it before posting and writing the code. What I gather is that, if you don't use memory-specific pointers you may very well pay a speed penalty, among other things.
    If I declare a generic pointer:
    U8 *generic_pointer;
    How do you propose to let a function like printf know whether to go to xdata or code space?
    printf(" %s", generic_pointer);
    won't work,
    printf(" %s", (U8 code *)generic_pointer);
    or
    printf(" %s", (U8 xdata *)generic_pointer);
    might work...but what penalty do we pay?
    I took the approach of making the cast once and then working with a memory specifc pointer for the rest of the function. Yet, wanting to make sure that this was a sensible approach I decided to post on the list.
    Are you of the opinion that I should use generics and simply cast when needed?
    Thanks.
  • "How do you propose to let a function like printf know whether to go to xdata or code space?"
    You don't. Most of the library routines deal with generic pointers. Again, read about generic pointers. They are 3-byte pointers encoded to specify the memory space they point to. Your dump routine could to likewise, taking a generic pointer and then "converting" it to a mspace-specific pointer for speed when necessary.
  • How do you propose to let a function like printf know whether to go to xdata or code space?
    That's exactly what's generic about generic pointers: they contain an extra byte to signal this difference. You may want to think of a generic pointer as a data type like
    struct generic_pointer {
        U8  memory_class;
        union {
          void code  *c;
          void xdata *x;
          void data  *d;
          void idata *i;
        } ptr;
    which was versatile enough that it was implemented as an intrinsic data type supported by the compiler and linker.
    won't work,
    Says who?
    The "address" to your function should almost certainly be a generic pointer. That's always better than abusing an int as a pointer, and particularly better than using arguments to specify one thing.
    And BTW: worrying about efficiency while in the same sentence proposing to use printf() to print a string seems considerably self-contradictive to me. ;->
