Pls assist to clarify if this C51 code is accurate?!
Hi All
Based on the following assemble code, I wrote a program with the same function in C51 code. However, my program seems to be inaccurate because I failed to collect data after its operation.(This means the complier passes, but I do not obtain the reslut that I have expected!)
If anyone could kindly point out the inaccuracy of my program--C51 code, I will be very grateful to you guys.
N.B. :
The assemble code shown below is correct,you do not have to check them anymore. Please simply review through C51 code. Thanks a lot :)
[assemble code start]
X EQU 30H
Y EQU 31H
EX EQU 32H
EY EQU 33H
XBUFFER EQU 34H
YBUFFER EQU 35H
DBUF EQU 36H
MOV X,#01
MOV Y,#01
MOV EX,#20
MOV EY,#80
MOV DBUF,#FFH
CALL DDRAMWR_BW_BLOCK
DDRAMWR_BW_BLOCK:
PUSH 1
PUSH 2
PUSH 3
PUSH 4
CLR C
MOV A,EX
SUBB A,X
INC A
MOV XBUFFER,A
CLR C
MOV A,EY
SUBB A,Y
INC A
MOV YBUFFER,A
MOV A,Y
DEC A
MOV B,#20
MUL AB
CLR C
ADD A,X
CJNE A,#00H,BW62_BLK
DEC B
BW62_BLK: DEC A
MOV R1,A
MOV A,B
ADDC A,#0
MOV R2,A
CLR C
BW22_BLK: MOV R3,XBUFFER
BW12_BLK:
MOV A,DBUF
CPL A
CALL DATA_WR
BW52_BLK: INC R1
MOV A,R1
DEC A
CJNE A,#255,BW32_BLK
MOV R1,#0
INC R2
CLR C
BW32_BLK: DJNZ R3,BW12_BLK
CLR C
MOV A,#20
SUBB A,XBUFFER
ADD A,R1
MOV R1,A
MOV A,R2
ADDC A,#0
MOV R2,A
DJNZ YBUFFER,BW22_BLK
POP 4
POP 3
POP 2
POP 1
RET
DATA_WR: ;Write data to MEM thru 1352
PUSH DPL
PUSH DPH
; CLR C
MOV DPL,R1
MOV DPH,R2
CLR P3.4 ;MEMCS#=0,
CLR P3.1
CLR P3.0
CLR P1.0 ;Ereset=0;
MOVX @DPTR,A
SETB P3.4 ;MEMCS#=1
POP DPH
POP DPL
RET
;--------------------------------------------[assemble code end]
[c51 code start]
unsigned char xdata * data Addr;
Show_bar(0x01,0x01,0x20,0x80,0xff);
void Show_bar(unsigned char x, unsigned char y,unsigned char ex, unsigned char ey,unsigned char DBUF)
unsigned char c,x1,y1,YHL,YH,YL,xbuffer,ybuffer;
CY=0;
c=CY;
xbuffer=(ex-x)+1;
ybuffer=(ey-y)+1;
YHL=(y-1)*0x14;
YH=(YHL&0xff00)>>8;
YL=(YHL&0x00ff);
c=0;
YL=YL+x;
if(YL=!0)
x1=YL--;
y1=YL+0;
else
YH--;
x1=YL--;
y1=YL+0;
loop1:
if(ybuffer!=0)
loop:
if(xbuffer!=0)
DBUF=~DBUF;
P3_4=0;
P3_1=0;
P3_0=0;
P1_0=0;
*Addr=DBUF;
P3_4=1;
x1++;
x1--;
if(x1!=255)
xbuffer--;
else
x1=0;
y1++;
c=0;
goto loop;
else
c=0;
x1=0x14-xbuffer+x1;
y1=y1+c+0;
ybuffer--;
goto loop1;
[c51 code end]
  • The C code is wrong. For starters, the type of variable YHL is way wrong, and you try to work with the CPU's carry flag from C code, which cannot work.
    The C code you showed leaves the impression that you're trying to win a professional race over 100 meters before having mastered proper walking. You're treating C as just a somewhat obfuscated variant of assembler (evident e.g. in all those gotos and labels). You're doing yourself more harm than good by using C here.
    So: please stop what you're doing, and go back to the start of your "How to learn a new programming language" project. Forget about the '51 for a while, and train plain C programming instead.
    is it even C code except for the syntax?
