Hi, I'm having trouble communicating to the LPC2138 device through the JTAG interface on the product I've designed. Downloading my firmware to the MCB2130 eval board works fine, however, when I try to download the firmware through the JTAG interface on my hardware I get a "JTAG Communication Failure" message. The only way I have found that I can get the JTAG to download to my custom board is when I remove the 10k pullup on the RST line, and put add some floating capacitance onto the resistors pad on the RST net (i.e. a pair of metal tweezers). Then the application downloads onto the micro just fine. Whilst the power is still on my board i can then download code to the LPC2138 just fine as many times as I like. When I cycle the power again, it fails to communicate UNTIL I perform the magic tweezer operation again. My setup is the same as on the MCB2130 eval board. 1) P0.31 is left unconnected (has internal Pull-up). 2) TRST, TDI, TMS, TDO have 10k pull-ups 3) TCK, RTCK have 10k Pulldowns 4) RST has a 10k Pullup (as per MCB2130 Schematic), and have tried adding a 100n Capacitor and diode across the 10k resistor as per the MCB2130-V14 schematics). I opened up the hood of the ULINK programmer and discovered that the RST line on the JTAG interface was connected to an *Input* on the 74LVC244AD. What drives the reset line from the ULINK? Has anyone experienced this issue? It's very frustrating! Kind Regards, Scott
The newest versions of the LPC2138 devices have a slightly modified boot software that requires different ULINK reset timings. Are you already using the CARM V2.40 release? This version takes care of that. Reinhard
Hi, No. I'm currently using V2.00d. Could you please point me to where I can download the latest version from? Thanks! Scott
Reinhard, Don't worry, I've found the download section. Thanks for your help! I'll let you know how it goes after I download and install the new version. Scott
Reinhard, It works! A *BIG* sigh of relief... hardware verified. It's now time to push the "manufacture" button :-D Cheers, Scott
