void enable_timer(void) { TH0=0x01; TL0=0x01; TMOD = (TMOD & 0xF0) | 0x01; ET0 = 1; TR0 = 1; EA = 1; } void serial_init(void) { PCON |= 0x80; SCON = 0x52; TMOD |= 0x20; TH1 = 0xF3; TR1 = 1; ES = 1; // PS = 1; EA = 1; } I don't know why when i use 2 subs to initialize serial port and timer 0 but i don't know why timer 0 runs so slowly.Could anyone can tell me the reason why and show me the solution?Please answer me soon because I need it
Hi, I haven't checked the rest of the timer 0 initialisation, but dont forget the counter counts up to 0xFFFF, not down to 0x0000! and you initialise it with 0x0101 so it has a long way to go. Is this what you intended? Mark.
How is CKCON set? what is clocking T0? Read-modify-write ops are used on TMOD, what is the absolute initial value? What is the state of the T1 interrupt? If you set TR1=0 does T0 run differently? Use your simulator and watch the peripheral windows, you'll see what's wrong.
