Identifying unused functions
I'd like to know if anyone has any hints on identifying unused functions using the C166 compiler/linker. We have a large codebase shared between multiple projects and it would be beneficial to code size if we could remove functions from certain versions that are not being used.
  • It's unfortunate that the C166 linker cannot remove unused functions from the binary image if they are from the same section (same C source file) as used ones. I believe that Keil probably put all their library functions into separate C files for this reason.
    The only solution I can come up with is using a tool like PC-Lint. Among its features is identifying unused functions.
    Regards,
    - mike
  • "I'd like to know if anyone has any hints on identifying unused functions using the C166 compiler/linker."
    Not using the compiler/linker, but use the Code Browser in uVision, and sort by the number of "references"
    If the number of "references" is only one - then that's just a definition with no uses.
    (If the number of "references" is two, that could mean that it's defined, declared in a header, and then not further referenced).
    Job done - that'll be fifty quid, please.
