printf doesn't work
I've a project with two targets, the XC167CI and the C167CR-LM. But if I want the program to print some information with printf, it doesn't work (flash version and sumulationon the XC167CI and the flash version for the C167...).
The initialization must be correct (I hope so)
/* defines for XC167CI */
#define S0TIC ASC0_TIC
#define S0RIC ASC0_RIC
#define S0BG  ASC0_BG
#define S0CON  ASC0_CON
void initSerial(void) {
  P3  |= 0x0400;
  DP3 |= 0x0400;
  DP3 &= 0xF7FF;
  S0TIC = 0x80;
  S0RIC = 0x00;
  #ifdef XC167
    S0BG = 0x81;
  #endif
  #ifdef C167
    S0BG = 0x40;
  #endif
  S0CON = 0x8011;
  #ifdef XC167
    ALTSEL0P3 |= 0x0C00;
  #endif
Moreover I've changed the startup code with
SSTSZ   EQU     0x50
USTSZ   EQU     0x50
MOV     STKUN,#0FFFEH  ; AVOID STKUN TRAP
MOV      STKOV,#0H     ; AVOID STKOV TRAP
   ;MOV     STKUN,#SOF (_TOS)
   ;MOV     STKOV,#SOF (_BOS+6*2)
   ;MOV     SP,#SOF (_TOS)
   ;MOV     SPSEG,#SEG (_TOS)
Where can be the bug? I already tried so much but can't find the problem.
Thank You
Norbert Rastl
PS.: memory model = "MEDIUM"
  • Hello again,
    I use the START_V2.A66 of the Version 4.04 for the XC167CI and the version or the chip works fine now, but not for simulation.
    I now use the the START167.A66 for the C167CR-LM and everything works fine in the simulation, but the version on the chip doesn't write. If i just initialize the interface and write something, it writes just one character.
    Does anyone know a solution for that?
    Norbert Rastl
  • Hello Norbert,
    as far as I remember you need for the XC16x devices at least V4.21 and higher.
    For the C167CR I unfortunatly do not know the answer.
    Stefan
  • Hello,
    and thanks Stefan. My program now also runs on the XC167CI (with Version 4.01).
    Can it be that the memory model or my settings for the external memory is wrong?
    "Medium"
    ROM: 0x50000 with size 0x3FFFF
    RAM: 0x100000 with size 0x3FFFF
    Norbert
  • I think the memory model will not be the critical point, since you could use different
    keywords like huge or xhuge ...
    I think that memory settings are the reason.
    printf() was crashing my system, only in the case where I adjusted wrong timing for RAM access.
    BTW: Should not the setting for an XC16x device looks like
    ROM 0x040000 size 0x3FFF
    RAM 0x100000 size 0x3FFF
    Stefan
  • What would be the better settings for a C167CR-LM?
    I now use the startup code in version 5.01. And everything runs perfectly in with the simulator but not on the chip. It does nothing. It does not even write a character after initializing the serial interface.
    Can it be that the On-chip XRAM makes problems?
