PORT ADDRESS!
I am using AT89C52 and I need to program such that I can read the data on PORT Pins in a specific pattern as described below:
P(x,y)
where x should be port number and
y should be pin number of the port to give me PX_Y
ex. P(0,5) == P0_5
How can I do this? Can anyone help me in this? Please mail me the solution on punit.ganshani@gmail.com
  • "ex. P(0,5) == P0_5"
    You can easily do that at compile-time with a #define macro - see any 'C' textbook.
    You can't do it directly at run-time, since 8051 ports are not indirectly addressable (none of the SFRs is).
    You'd have to do something like:
    bit read_port( U8 port_num, U8 bit_num )
       switch( port_num )
          case 0: return P0 & (1<<bit_num); case 1: return p1 & (1<<bit_num); < i>etc...
