Data recieved from UART does not latch on any Port
I have this very strange problem. I am recieving data on UART and when I try to throw the data on any port, it shows up mometarily on the port and then all the port goes to zero. I do not understand this but the code works fine in debugger with SIN command.Here is the code if any one want to give a suggestion .Thanks
#include "REG51CC01.h"
void serial_IT(void) interrupt 4 using 2
char uart_data=0;
if (RI == 1)
RI = 0; // clear reception flag
uart_data = SBUF; // Read data
P2=uart_data; //Output recieve data
void main (void)
unsigned char del=0;
SCON = 0x50; /* uart in mode 1 (8 bit), REN=1 */
T2CON &= 0xF0; /* EXEN2=0; TR2=0; C/T2#=0; CP/RL2#=0; */
T2CON |= 0x30; /* RCLK = 1; TCLK=1; */
TH2=0xFF; /* init value */
TL2=0xFD; /* init value */
RCAP2H=0xFF; /* reload value, 115200 Bds at 11.059MHz */
RCAP2L=0xFD; /* reload value, 115200 Bds at 11.059MHz */
ES = 1; /* Enable serial interrupt */
EA = 1; /* Enable global interrupt */
TR2 = 1; /* Timer 2 run */
while(1);
  • looked at youyr code twice, saw nothing bad.
    1) I take it you do not hav any external memory
    2) are you absolutotally sure that no zero bytes come down the pipe, try just for kicks
    if (RI == 1)
      if (uart_data == 0)
    If that works, you have 2) above
  • Thanks for your reply, Eric.
    Yes, I do not have any external memory.
    Secondly, I also thought there may be something following my first data that overwrites it so I counted the number of interrupts and there is exactly one interrupt after I send one data to UART.
    Now here is another strange thing, if I run this program with if statement in interrrupt routine as shown in the following program it works just fine. But I guess by using this approach I can not recieve zero on UART.
    char uart_data=0;
    if (RI == 1)
    { /* if reception occur */
    RI = 0; /* clear reception flag for next reception */
    uart_data = SBUF; /* Read receive data */
    if(uart_data)
    P2=uart_data;
    void main (void)
    while(1);
  • Can you post the assembly code generated for the interrupt handler?
    I have a vague recollection of a couple of recent bug fixes that had to do with comparing bits and integers. What does
    if (RI == 1)
    compile into? What about
    if (RI)
