Hi I have found the codes and I am trying to understand the code as it is about generating sine wave but I got lost in the offset sections. I would be grateful if you offer any help me to understand the codes as shown below: In fact I would expect the PWM frequency should be 5kHz and the frequency modulation - 400Hz
// Timer 0 & 1 - Timer mode (Non-staggered) // T0I - 000 hence prescaler would be 1, period = 1.6384ms // T1I - 111 hence prescaler would be 128, period = 209.72ms CC1_T01CON = 0x0700; // Since I don't know what is the desired period for timer 0 & reload (0XF060) // Hence 61536=(DESIRED PERIOD/1.6384E-3)*65536 // DESIRED PERIOD would be 1.5384e-3 (650Hz) C1_T0 = 0xF060; CC1_T0REL = 0xF060; // CAPCOM1 : CC1_CC2/3 ARE ALLOCATED TO TIMER TO // : Mode 3 are set for CC2 and CC3 CC1_M0 = 0x7700; ALTSEL0P6 |= 0x003C; // select alternate output function DP6 = (DP6 & ~(uword)0x003C) | 0x003C; //set direction register // Enable the CAPCOM1 Timer CC1_T01CON_T0R = 1; // set CAPCOM1 timer 0 run bit // Obtain the offset but I don't understand the reason behind this method offset = (0xFFFF - CC1_T0REL)>>1; // Generating look up table for sine wave TempFloat = TABLE_SIZE; // 50 TempFloat = (360)/TempFloat; // Get the increment size for the sine wave look up table for (loopcount=0; loopcount<TABLE_SIZE; loopcount++){ SineWave[loopcount]=(offset*sin(((loopcount*TempFloat)*3.14159)/180)); } // I don't why offset is added to CC1_TOREL (Can anyone care to explain reason behind this?) CC1_CC2 = CC1_T0REL + offset; CC1_CC3 = CC1_T0REL + offset; CC1_CC2_Temp = CC1_CC2; CC1_CC3_Temp = CC1_CC3; // Can anyone please tell me what _sof_ is for? SRCP5 = _sof_(&CC1_CC2_Temp); SRCP6 = _sof_(&CC1_CC3_Temp); Interrupt routine for CC1_T0INT int TempInt; long int TempLong; pwm_ref++; if(pwm_ref >= 50){ pwm_ref = 0; } TempLong = 5000; // amplitude TempLong = SineWave[pwm_ref]*TempLong; TempInt = (TempLong)/10000; // Can someone please please tell me what is the hell is going on epecially two last codes // CC1_CC2_Temp = CC1_T0REL + (offset + TempInt); // apply sine wave CC1_CC3_Temp = CC1_T0REL + (offset - TempInt); // apply sine wave
What if I need to implement PWM Frequency of 50kHz but Need to generate 400Hz sine wave? Is there any specific forumla for me to carry out? Can someone please tell me how to generate sine wave? I am aware that duty cycle is used to produce sine wave by looking the table up. AJ
