interfacing problem
I am doing a project in which I am using Microcontroller Atmel 89C52. The problem I am facing is interfacing between MatLab and Keil.
Characters sent by MatLab are directly recognised as characters by Keil, but I am having problems in Integers being sent by MatLab and recognised by Keil.
Although both Keil & MatLab use C hence their data types are same
Keil data type:
signed int bits:16 bytes:2 range:-32768 to +32767
unsigned int bits:16 bytes:2
range:0 to 65535
data types in MatLab
uint8 range: 0 to 255
Unsigned 8-bit integer
bytes per element: 1
uint16 range: 0 to 65535
Unsigned 16-bit integer
bytes per element: 2
uint32 range: 0 to 4294967295
Unsigned 32-bit integer
bytes per element: 4
the range of unsigned integers match in both MatLab & Keil then why the problem?
1:_getkey only reads characters
2:unsigned int a;
scanf("%u",a);
(not working why?)
please help.....
