Problems with the communication with analog input module.
I am trying to communicate a microcontroller P89c51RD through serial port with a analog input(AI) module ICP_DAS. The AI has an own communication protocol, (send #011 and it responds to channel 1, i.e +0.065), using other languages (LabView) I have not had any problem to read the analog input.
I have made sure that the configuration of the port is correct, that the format of the sent data is adapted (string). But I do not know that it happens, because microcontroller does not receive anything.
Part of my code is this:
// Function to send command to read analog input.
bit lee_AI_ICP(void)
{   	bit send;
	char lee_ai[10]="#011";
	printf("%s\r", lee_ai);
	send=0;
	return send; }
// Part of main routine
while(1) {
	if (send&&buffer_full) {
	send=lee_AI_ICP();
	buffer_full=0; }
	if (RI&&(!buffer_full)) {
	medida[buf_cnt]=_getkey();
	buf_cnt=++buf_cnt;
	RI=0; }
	if (buf_cnt==6) {
	buffer_full=1;
	buf_cnt=0;
	send=1; }
I think that with this code it would have to be receiving the values in ASCII of each of the numbers that form the resulting value of the measurement of the AI.
It would thank for any suggestion, correction or modification in the code.
Greetings to all.
