Under UV3 IDE Compiler GCC331(down load from http://www.keil.com) MCU = ADuC7026 I define a union like: typedef union _epp_flags { struct _flags { unsigned char timer : 1; unsigned char bus_reset : 1; unsigned char suspend : 1; unsigned char setup_packet : 1; unsigned char remote_wakeup : 1; unsigned char in_isr : 1; unsigned char configuration : 1; unsigned char verbose : 1; unsigned char ep1_rxdone : 1; unsigned char power_down : 1; unsigned char control_state : 2; unsigned char setup_dma : 2; unsigned char dma_state : 2; } bits; unsigned short value; } EPPFLAGS; then define a varible like : EPPFLAGS bEPPflags; the Compiler will make the bEPPflags.bits.timer at the lowest byte's lowest bit of union but the IDE thought the the bEPPflags.bits.timer at the lowest byte's highest bit!! So under Simulation debug, after executed bEPPflags.bits.timer = 1; In Watch Window you will find the bEPPflags.bits.verbose(8th variable) change to 1 and bEPPflags.bits.timer is still 0!!! Which mean that the UV3 IDE and GCC compiler have different order to allocate variable in the union!!! So the Watch Window give the wrong answer!!!
I think that the problem might be caused due to mis-aligned 'int' variables. Does this happen with the current CARM version 2.20? If so, please send a test project to: support.intl@keil.com Reinhard
Yes, CARM2.20 have this error too. (I use GCC331 Compiler).
OK.
