INT0(P1.3) LPC935 in simulation not working while INT1(P1.4) works fine
Hi all,
I am having a problem with the simulation of my project which uses both external Interrupts, Interrupt 0 and Interrupt 2. I enable all the signals necessary to enable the Interrupts. When in simulation I lower the Bit 1.4, the Interrupt 2 routine is executed, but when i lower P1.3 in simulation, the interrupt 0 is not executed. Is there a problem with simulator or any other clue.
Best wishes, (i havent tested yet on the evaluation board, but in simulation it doesnt work, maybe others have the same problem)
thank you, any help is appreciated
Khaled
