i want to do a project " embeded web server using 8051 microcontroller(AT89c51)",i need help. is there any ethernet chip availble instead of eisa card for NIC interfacing.i need help in this regard?
Do you have to use the Atmel part? There are a number of 8051 microcontrollers with integrated 10/100 Ethernet controllers -- for example, the Dallas Semiconductor DS80C400 series. Here http://www.hhsw.co.uk/EmbeddedEthernetPlatform.htm is an eval board with an AT89c51 and a Cirrus Logic CS8900A 10baseT controller.
Go to Atmel's website, and type "@Web" into the 'Search' box Or take a look at this: http://www.tdc.co.uk/manufacturers/connect_one.htm Or this: http://www.keil.com/forum/docs/thread6784.asp Or this: http://www.sics.se/~adam/uip/ Or this: http://www.keil.com/tcpip/ Or spend a little time with your favourite internet search engine...
