ez-usb FX & timer0 interrupt (keil newbie)
I'm new with Keil software , but however
I have experience in writing software for
the 8051/8052 in assembly.
My problem:
I'm making changes in firmware for the FX1
of Cypress. I want to add a timer0 interrupt
and searched through the forum and application notes. Appnote 105 and 126 were usefull, and
I created this:
Global:
BYTE xdata I2CPOS=0;
main() :
// timer 0 interrupt
TMOD &= ~0x0F;
TMOD |= 0x01;
TH0=0xFF;
TL0=0x00;
PT0 = 0;
ET0 = 0;
TR0 = 1;
// enable interrupts
EA = 1;
routine:
void timer0_isr(void) interrupt TMR0_VECT
TH0=0xFF;
TL0=0x00;
I2CPOS=0;
The timer0_isr is never called, what do I forget. Is the timer0_isr(void) automaticly
added to the vector table or has this to be
done manually?
The FX1 uses autovectoring for the usb
interrupts does this affect the standard
interrupts?
  • ET0 = 0;
    This disables the timer interrupt.
    Jon
  • Eh yes, ET was at first 1 , but I disabled it
    for debug purpose.
    As soon as ET=1 , enumeration will fail, this
    is probably caused by an non-existing interrupt
    routine.
  • The head of the main list says:
    #pragma NOIV // Do not generate interrupt vectors
    As far as I understand this will inhibit the
    default vector table and an alternative
    table will be used. How can I use both the
    alternative table and the standard table?
  • The key question above is: 'How do I use both the standard interrupt table as well as the alternate table?'
    Answer: you must modify the alternate table USBJmpTb.a51 to include the standard vectors.
    Here are snippets from my modified USBJmpTb.a51 file.
    NAME USBJmpTbl
    extrn code (TIMER0OF, TIMER2OF, UART0IRQ, UART1IRQ) /* This line is added to handle the standard 8051 INTs. Names refer to my INT handler functions located elswhere. */
    extrn code (ISR_Sudav, ISR_Sof, etc... as provided in the unmodified USBJmpTb.a51 file...)
    ; Interrupt Vectors
    /* The following four CSEG sections put the proper jumps at the proper addresses to handle the four standard 8051 interrupt sources that I am using in my project. */
    CSEG AT 0BH
    ljmp TIMER0OF
    CSEG AT 23H
    ljmp UART0IRQ
    CSEG AT 2BH
    ljmp TIMER2OF
    CSEG AT 3BH
    ljmp UART1IRQ
    ; The rest of the USBJmpTb.a51 file is 'stock.'
    CSEG AT 43H
    USB_Int2AutoVector equ $ + 2
    ljmp USB_Jump_Table ; Autovector will replace byte 45
    Good luck all!
    Del
