Using C variables in Assembly language code
I have C source file where the code is a mixture of C language code and assembly language code. I want to use a C variable in that assebly language code how do i do it? Any help is welcome.
(I can do this with IMPORT keyword in ARM . is there anything similar here.)
thanks
kaushik
Ex-
main()
//normal C code
unsigned char arr[100];
________________________________
//assebly language code starts here
I want to use arr[100] here
//assebly language code ends here
normal C code
