hi, I am using the external data memory (xdata) to store some variables,since my internal data memory(256 bytes)overflows. The test case executes without error for small memory model(If i remove some variables),but it fails for large memory model. For example if char dest[30]="mark"(declaration) makes the data memory to overflow, i replaced the declaration as xdata char dest[30]="mark".Now it creates hex file without any error.But the test case fails.can any one tell me what may be the reason for the failure?. Note:The test case works properly for small model Thanks in advance chris
Note that using the 'xdata' keyword doesn't change the memory model. Do you have your external RAM size and start address specified correctly in the project options?
Thanks a lot stefan! It works fine now. regards chris
