What's wrong with the define of STRUCT?
Hello all,
My project with 3 files as following ,the MAIN is in sys.c,all 3 files are compiled well each other.
File a: including sys.c and common.h
File b: including rtk.c and rtk.h
File c: including blt.c and blt.h
rtk.h:
extern uchar code rtk_Cmd[20]={...};
extern struct Time
{uchar Sec;...};
extern struct Date
extern struct Time sGps;
rtk.c:
#include <rtk.h>
syc.c:
#include <common.h>
#include <rtk.h>
#include <blt.h>
void main()
Func1(sGps.Sec);
Func2(rtk_Cmd);
when build all files, the error L104:mutiple public defintion (rtk_cmd)
Warning L1: unresolved external symbol(sGps).
Give me your hands ,thanks a lot!
  • "error L104:mutiple public defintion (rtk_cmd)"
    Don't initialise in the header!
    The initialisers must appear in exactly one 'C' source file.
    "L1: unresolved external symbol(sGps)."
    Your rtk.h has an extern declaration of sGps, but where is the definition?
    Again, the definition must appear in exactly one 'C' source file.
  • And now,
    rtk.h:
    struct MesInfo
    struct MesInfo GpsInfo;
    rtk.c:
    #include<rtk.h>
    Func1(GpsInfo.*);
    sys.c:
    #include<common.h>
    #include<rtk.h>
    void main()
    Func2(GpsInfo.*)
    all *.c can be compiled well.
    Even in the common.h has "extern struct MesInfo GpsInfo;"or not.when built all files,"error L104 :Mutiple public defintion(GpsInfo)" is show.What's the matter?
  • You have DECLARED GpsInfo in rtk.h Then, you include rtk.h in both rtk.c and sys.c files - therefore you have declared it twice (in both of files) - resulting in "Multiple public definition" error.
    - Dejan
  • Thank you for your help.
    I have resolved it as follow:
    rtk.h:
    struct MesInfo
    rtk.c:
    #include<rtk.h>
    sys.c:
    #include<rtk.h>
    In this way,all files can be build ,is it right?
  • In this way,all files can be build ,is it right?
    It may work, but it's not right.
    As a rule of thumb: never write 'extern' in a .c file --- it only ever should appear in .h files.
    In your case, this line:
    really belongs into rtk.h, because that's the interface description for rtk.c, and GpsInfo is part of the published interface of rtk.c.
  • "You have DECLARED GpsInfo in rtk.h Then, you include rtk.h in both rtk.c and sys.c files - therefore you have declared it twice (in both of files) - resulting in 'Multiple public definition' error."
    Not quite:
    He has defined GpsInfo in rtk.h - resulting in 'Multiple public definition' error.
    The definition must be in exactly one source file; there can be as many extern declarations as you like!
