In Application Loader and RTX Tiny
I'm looking into using RTXTiny for a project with a Cygnal F020. However, the device requires end-users to be able to update firmware via USB.
Is is possible to move RTXTiny and applications a few thousand bytes higher in memory in order to be able to use lower memory for the loader code?
Are there any examples of this sort of thing anywhere?
Also, I know that one can relocate ISR's and even have dual (loader & application) ISR's. Is this still possible with RTXTiny?
I suppose RTXTiny AND loader could all reside in low memory. Maybe that's the right approach?
Thank you,
-Martin
  • I think about RTX_MAXTASKN number that linker fills to rtx_conf.obj. If you want to rtx-tiny be with loader, you can not change number of tasks of loaded aplication. Othervise I think it's possible to do a loader with rtx in lower. You must aslo re-route interrupts to your aplication area.
    Roman
