Hallo all, What does the LSL/LSR Instruction ? IAR C for ARM does not need it. Thanks Gerhard
*** CODE SEGMENT '?PR?DF_WriteToDataFlash?T?dataflash': ARM COMPILER V2.00, dataflash 180: VOID DF_WriteToDataFlash(CHAR cData) small 00000000 B500 PUSH {LR} 00000002 ---- Variable 'cData' assigned to Register 'R0' 196: SBUF = cConvTab[cData]; 00000002 0601 LSL R1,R0,#0x18 ; cData 00000004 0E09 LSR R1,R1,#0x18 ; cData 00000006 4800 LDR R0,=cConvTab ; cConvTab 00000008 5C41 LDRB R1,[R0,R1] 0000000A 4800 LDR R0,=SBUF ; SBUF 0000000C 7001 STRB R1,[R0,#0x0] ; SBUF 197: _nop_(); 0000000E F7FF BL _nop_?T ; T=0x0001 (1) 00000010 FFF7 BL _nop_?T ; T=0x0001 (2) 198: _nop_(); 00000014 F7FF BL _nop_?T ; T=0x0001 (1) 00000016 FFF4 BL _nop_?T ; T=0x0001 (2) 216: } 0000001A BC08 POP {R3} 0000001C 4718 BX R3 0000001E ENDP ; 'DF_WriteToDataFlash?T'
"What does the LSL/LSR Instruction ?" Surely that'll be answered in the ARM instruction set manual? "IAR C for ARM does not need it." The whole point of 'C' (or any other high-level language) is that the compiler is free to choose whatever machine instructions it sees fit!
LSL = Logical Shift Left LSR = Logical Shift Right It looks like the compiler generates this code to sign extend the char cData. Jon
The LSL/LSR sequence is identical to AND R0,#0xFF (but does not require an extra register). Other compilers need for sure similar constructs when the following is written:
int i = 0x122; void func (char c) { if (c == 0x23) return; i = 0; } void main (void) { func (i+1); }
True, with just int's, the Keil Compiler optimizes much better :-) Thanks Gerhard
