Timer increases, but variable not ...
Hello, I have a problem with this code:
void test(void)
  unsigned long time_start, time_diff;
  unsigned int x=2;
  time_start = timer_value;
  while (x<5)
        time_diff = timer_value;
        if (time_diff-time_start >= 2ul) x=5;
	//  printf("%X\n", time_diff-time_start);
timer_value is incremented by Timer T0 10 times a second (IRQ-Routine). This part of code should wait for approx. 0.1 .. 0.2 seconds. But if there is no printf-Command timer_diff doesn't increment. If I stop the Debug-Mode of uVision and take a look at timer_value then it really increased, but time_diff still got the same value as time_start. Why?
If the printf-Command is included, everything works fine ...
Thanks for any hint
Torsten
