Hi We are using muVision3 V3.23 (CA.EXE vs 2.41) with a MCB2140 board with LPC2148. We are using the EX8-IAP example program as a basis for flash programming to prepare an upgrade function of our system via USB. I noticed that the project is thumb code, while the main() function is declared __arm. Our project is currently thumb code. 1) Does this mean that all functions calling iap_bypointer(command,result) should be declared __arm? 2) Many example code fragments refer to external functions via the extern keyword, instead of using header files. Is there a specific reason for this, other than to spare the .h file? How should an __arm function be declared in a (thumb) .h file? 3) Are there known issues with IAP in combination with MBC2140, LPC2148, JTAG and uVision; we are experiencing odd behaviour varying from Undefined Instructions, Prefetch and Data aborts, breakpoints that become invalid when stepping through the code, and occasionally we loose the JTAG connection, a situation which only an erase with the LPC210X utility program can solve. Thanks for your help Jeroen
There are no problems with IAP programming, however since each chip is slightly different you need to adapt the examples. Another example is at: http://www.keil.com/download/docs/298.asp?bhcp=1
