Hello, I am using BankSwitching with XdataPort. In the BankSwitching Assembly file exists a public variable called '?B_CURRENTBANK'. I would like to access this variable from my C-program: extern char ?B_CURRENTBANK; void main(void) { char ucTest; ucTest = ?B_CURRENTBANK; } The compiler gives me the following Error: error C141: syntax error near '?' . Could somebody help me? Thanks
'?' isn't a legal character for a 'C' identifier, is it...?! It is common for 'C' Compilers to do some "translation" between the identifiers in your source code and the symbols emitted to the object file; eg, adding an underscore prefix is common. This is described in the C51 Manual - look up "Naming Convention" or similar.
http://www.keil.com/support/docs/1320.htm Jon
