Hello, Is it normal that EC++ won't compile properly if a variable is called "priority" or "_priority"? Example:
unsigned int priority = 1; unsigned int _priority = 1;
extern void os_init_context (P_TCB p_TCB, U8 priority, FUNCP task_body, U8 full_contxt);
Why don't you post the actual text of the error message?! Use cut-and-paste; don't re-type it.
Neil, I copied all I could here: Copy of bug.cpp
compiling bug.cpp... bug.cpp(1): error: expected an identifier
Andy, My mistake, I didn't mean to call you by your last name :p Steph-
Well, you're not the first to do it - but I think you are the first to admit the mistake! Thanks. Anyhow, it certainly does look like EC++ is treating "priority" as some special keyword. Are you sure it isn't being #defined somewhere in your project? Can EC++ give you a preprocessor listing?
Andy, Since the error is thrown by the EC++ parser, there is no "bug.ic" C listing generated. The only file generated is the bug._ii file, which contains nothing but one line: bug._ii:
"bug.cpp" HLARGE
#include <stdio.h> unsigned int priority = 1;
#include <stdio.h> #undef priority unsigned int priority = 1;
Stephane, priority, _priority, _priority_ and __priority are keywords in the EC166 compiler. They all mean the same and are used to pass 'task' specific info to the C166 compiler. Please see the example below on how they are used. Peter
volatile int c16, c17; bit c16Bit; void Task4 (void) __task 4*4 __priority 2*3 __using REG_RB2 { ++c16; --c17; c16Bit = 1; }
Not quite. - priority, _priority and __priority are EC++ keywords. - _priority_ is a C keyword, not EC++ - priority and _priority should not be EC++ tokens, for they are used elsewhere in Keil AR166 headers, and not documented in the EC++ manual. Let me get to the point then: it would be really cool if the next version of AR166 headers could compile successfully with EC++! Rgds, Steph-
