Following on from this discussion: http://www.8052.com/forum/read.phtml?id=84814 Keil C51 v7.50 rejects the following:
char key_tbl[][] = { { 4, 3, 2, 1 }, // row 0 { 8, 7, 6, 5 }, // row 1 { 12, 11, 10, 9 }, // row 2 { 16, 15, 14, 13 }, // row 3 };
MAIN.C(27): error C163: 'key_tbl': unknown array size
Out of "The C programming language" section A8.6.2: "Any type from which an array is constructed must be complete; it must not be an array or structure of incomplete type. This implies that for a multi-dimensional array, only the first dimension may be missing." Therefore it should be:
char key_tbl[][4] = { { 4, 3, 2, 1 }, // row 0 { 8, 7, 6, 5 }, // row 1 { 12, 11, 10, 9 }, // row 2 { 16, 15, 14, 13 }, // row 3 };
In a multi-dimensional array, only the leftmost [] can be left empty. All other bounds must be specified. Note that initializers are not all or nothing. You can legally initialize just a bit of an array, while all the rest default to zero: char arr[10] = { 'a', 'b', 'c' }; This fact prevents the compiler from deducing the size of inner elements soley from the initializer. I've moved away from the practice of undeclared array sizes. Generally your specs or design docs tell you how many entries you must support. And the size of the array is often needed in loop bounds and other places. sizeof() can sometimes, but not always, determine the size of the array. So, I find it better to #define an array size constant (or often, use an extra value in a enum for that purpose). This constant is used in the array definition as well as other places to ensure consistency and allow the compiler to provide error messages for lack of initializers or too many initializers.
"Out of 'The C programming language' section A8.6.2" Which edition of the book is that? Mine's the 2nd Edition, marked "Based on Draft-Proposed ANSI C," and contains that very paragraph. However, The ISO/IEC 9899:1990 standard doesn't - that's where all the stuff about fully-bracketed initialisers comes from (Section 6.5.7). There's a draft copy of the C9x spec here: http://members.lycos.co.uk/learnprogramming123/C9X.txt See section 6.7.8 and then the subsequent paragraph numbers #17 to #22 about array / structure initializers that are fully bracketed. However, as Drew says, it begs the question of how it would cope with something like:
char key_tbl[][4] = { { 4, 3, 2, 1 }, // row 0 { 8, 7, 6, 5 }, // row 1 { 12, 11, 10, 9, 91, 92 }, // row 2!! { 16, 15, 14, 13 }, // row 3 };
There's a draft copy of the C9x spec here: Careful there. That draft copy is a dangerous document to quote, these days. The document being drafted there is no longer in draft status, and there are non-negligible differences between the draft and the real thing. But that's not the worst of it. That document describes C99, but C51 doesn't even try to be C99 compliant (yet), so neither this draft nor the actual standard document that it eventually became, can meaningfully be applied to this problem. And I'm quite sure that C90 never allowed [][] arrays.
"That document describes C99, but C51 doesn't even try to be C99 compliant" I couldn't actually find a specific reference here or in the Manuals as to precisely what "ANSI" Keil C51 complies to? But, yes; I'm sure it's not C99. However, ISO/IEC 9899:1990 does contain nearly all of the words cited from that C99 draft (and differs from the book). The language is pretty opaque, but it does seem to be implying that it ought to work...? "And I'm quite sure that C90 never allowed [][] arrays." That's what I thought - and for the reasons already provided here.
<quote> "Out of 'The C programming language' section A8.6.2" Which edition of the book is that? Mine's the 2nd Edition, marked "Based on Draft-Proposed ANSI C," and contains that very paragraph. However, The ISO/IEC 9899:1990 standard doesn't - that's where all the stuff about fully-bracketed initialisers comes from (Section 6.5.7). </quote> My copy is Second Edition -- ANSI C. As others have mentioned I don't see where KEIL says which ANSI C standard they are trying to meet. I've always assumed ANSI-83 ( 83 is the 1st one isn't it? ). :-) Frodak
I've always assumed ANSI-83 ( 83 is the 1st one isn't it? No, it's C89 (ANSI) a.k.a. C90 (ISO edition of same). There was no earlier edition. Before ANSI C89, there was no formal standard definition of C, so the book written by the makers of C served that purpose.
