Monitor & address windows
I am using the Keil Monitor to debug my program on a ST10F269. Until recently I used the default monitor configuration for my hardware (Phycore 167HSE, 1MB ROM, 2X 512kB RAM), which is included by Keil in it's development software:
(uVision3 V3.02)
However, when I make certain changes in the address-window configuration (Startup.a66 file in my project), the monitor program crashes.
This is my previous working hardware configuration:
CS1 0x0-0x80000 (512kB RAM, for monitor)
CS2 0x1000-0x2000 (4kB for an external UART)
CS0 controlls the ROM-chip (1MB), which is not used when the monitor is active.
The compiler only uses a fragment of the available RAM-space for my program. This space is located after the CS2-window (now at 0x10000 = 64kB), so no code gets overwritten.
When I change the address window size for CS2 to 8kB or greater (e.g. 0x1000-0x3000 for a 8kB window), The monitor crashes.
According to ST's uP-manual, it is permitted for CS2 to overlap CS1.
After some experimenting I found out that when the size before the CS2-window (0x0 -> CS2-window start) is >= the size of the CS2-window all is OK, when it is smaller than the CS2-window things go wrong...
I also tried to change the ADDRSEL/BUSCON configuration of the monitor. I entered the same windows in the Config.inc file as mentioned before.
This gives similar results:
1)
CS2: 0x1000 - 0x2000 (4kB)
This works fine
2)
CS2: 0x1000 - 0x3000 (8kB)
With the following settings, the Monitor loads properly, and proceeds with the loading of the user program, but when almost finished loading, is gives the error messages:
*** MONITOR ERROR 3: CANNOT WRITE TO ADDRESS 000003
... (etc.)
*** MONITOR ERROR 3: CANNOT WRITE TO ADDRESS 0000D3
Those are the interrupt vectors I'm using.
The disassembly windows shows:
00000000 FA01E203  JMPS     ?C_STARTUP(0x103E2)
00000004 E6E6E6E6  MOV      P6,#0xE6E6
00000008 E6E6E6E6  MOV      P6,#0xE6E6
0000000C E6E6E6E6  MOV      P6,#0xE6E6
00000010 E6E6E6E6  MOV      P6,#0xE6E6
00000014 E6E6E6E6  MOV      P6,#0xE6E6
00000018 E6E6E6E6  MOV      P6,#0xE6E6
... (etc.)
Are those results correct (and I missed something) or is there something wrong here?
Regards,
-Dirk
