I got a Improper fixup error when I link my program. It says that MODULE: ..\obj\startup.obj (?C_STARTUP) SEGMENT: ?C_C51STARTUP OFFSET: 002AH However, I check the list file and canot figure out what's wrong. Pls help
0020 D281 171 SETB SDA 0022 D280 172 SETB SCL 0024 208103 173 JB SDA, IAP1 0027 208004 174 JB SCL, IAP_FORCE 002A 1100 F 175 IAP1: ACALL MARK_CHECK 002C 70D2 176 JNZ STARTUP1 ;jump to application 002E C280 177 IAP_FORCE: CLR SCL 178 ;delay to let win32 handle 0030 E4 179 CLR A 0031 FD 180 MOV R5, A 0032 0D 181 WAIT2: INC R5 0033 BD00FC 182 CJNE R5, #00, WAIT2 183 EXTRN CODE(tdDebugFirmware) 0036 120000 F 184 LCALL tdDebugFirmware 0039 020000 185 JMP 0H 186 187 003C 188 MARK_CHECK:
if (t_TOE.ucMenuLevel) return;
hi, I just found out that this problem has sth to do with the ?CO? in my program. Strange. Why function pointer tables bring along fixup error?
Try searching in the Knowledgebase. and don't forget to specify the toolset when posting!
It says that MODULE: ..\obj\startup.obj (?C_STARTUP) SEGMENT: ?C_C51STARTUP OFFSET: 002AH OK. If you look in that module at offset 00@ah, you'll see the following line:
