I'm using the frequencies generated by the timers T3 and T6 for driving 2 stepper motors. The direction of the pins P3^1 and P3^3 equal 1. T3OE and T6OE equal 1 too. If timer 3 or timer 6 are generating an IRQ in the bootstrap mode the correspondending pins P3^1 / P3^3 are toggled. But if i load the program to flash, everything works, but on P3^1 and P3^3 there doesn't change anything. The program says, that T3OE and T6OE are set to 1, the timers are running, IRQs are working and T3OTL/T6OTL are toggling too. If I do the transitions on the pins manually:
sbit p_T3 = P3^3; sbit p_T6 = P3^1; ... void T3_timer_init() { T3=2000; T3CON = 0x0481; T3IC = 0x78; // ILVL=1110 GLVL=00 T3IE=1 } void T6_timer_init() { T6=300; T6CON = 0x0481; T6IC = 0x79; // ILVL=1110 GLVL=01 T3IE=1 } void interrupt_T3 (void) interrupt (0x23) { p_T3 = ~p_T3; // toggling P3^3 } void interrupt_T6 (void) interrupt (0x26) { p_T6 = ~p_T6; // toggling P3^1 } void main(void) { timer_init(); IEN=1; T3OE=1; T6OE=1; T3R=1; T6R=1; while(1); }
Both DP3.1 and P3.1 (DP3.3 and P3.3) have to be initialized to 1. Have you done that? Sauli
ehem ... no, i didn't initialize P3.3 and P3.1 :) thanks a lot, now it works Torsten
