i am getting problem with XDATA
Dear sir,
I am using C8051F124 microcontroller.i am connected 64KB external memory to the upper ports (as multiplexed mode) and i am writing program by using Keil compiler to display the externally stored data (from 0x0000 to 0x2000) on the LCD.
In the Target dilog box of keil compiler i am selected memory model as small:variables in DATA then the program was working fine.
When i am selecting memory model as Large:variables in XDATA then the program was not working and LCD was not initialising.
Please tell me the solution.
Thanking you.
