I want to extrn a function in asm in C. example: _asm { extrn test:near call test } like the example: but I have a exception like that: inline syntax error in 'opcode'; found 'test'
Hi, I don't see why you want to do this. You can do it in C:
extern void test(void); // before your main function ... test(); // in the middle of some code.
I already find the way to solve this problem. Thanks for your help. Best Regrad
