Problems to compile code
I have the following problem with the Keil compiler:
when I want to debug my c code, then the following error messanges come up: Error: Could not load file D:\path......\Test.ELF
Debugger aborted.
what is the reason for this, and how can I solve this problem?
thank you
regards
Samuel
