void test() { #pragma asm MOV R0,#55H #pragma endasm } this code generates A45 error:undefined symbol
If you just mindlessly keep reposting the same question withou answering the requests in the previous posts, the jack of diamond will be a king before your problem get solved. WErik
You ARE using the SRC directive, aren't you? When I compile your example, I get the following .SRC file.
; .\main.SRC generated from: main.c ; COMPILER INVOKED BY: ; C:\Keil\C51\BIN\C51.EXE main.c ; BROWSE DEBUG OBJECTEXTEND CODE ; PREPRINT SRC(.\main.SRC) NAME MAIN ?PR?test?MAIN SEGMENT CODE PUBLIC test ; void test() RSEG ?PR?test?MAIN test: ; SOURCE LINE # 1 ; { ; SOURCE LINE # 2 ; #pragma asm ; MOV R0,#55H MOV R0,#55H ; #pragma endasm ; } ; SOURCE LINE # 6 RET ; END OF test END
A51 MACRO ASSEMBLER MAIN 09/16/2004 10:10:27 PAGE 1 MACRO ASSEMBLER A51 V7.09 OBJECT MODULE PLACED IN main.OBJ ASSEMBLER INVOKED BY: C:\Keil\C51\BIN\A51.EXE main.SRC SET(SMALL) DEBUG EP LOC OBJ LINE SOURCE 1 ; .\main.SRC generated from: main.c 2 ; COMPILER INVOKED BY: 3 ; C:\Keil\C51\BIN\C51.EXE main.c ; BROWSE DEBUG OBJECTEXTEND CODE ; PREPRINT SRC(.\main.SRC) 4 5 6 NAME MAIN 7 8 ?PR?test?MAIN SEGMENT CODE 9 PUBLIC test 10 ; void test() 11 ---- 12 RSEG ?PR?test?MAIN 0000 13 test: 14 ; SOURCE LINE # 1 15 ; { 16 ; SOURCE LINE # 2 17 ; #pragma asm 18 ; MOV R0,#55H 0000 7855 19 MOV R0,#55H 20 ; #pragma endasm 21 ; } 22 ; SOURCE LINE # 6 0002 22 23 RET 24 ; END OF test 25 26 END SYMBOL TABLE LISTING ------ ----- ------- N A M E T Y P E V A L U E ATTRIBUTES ?PR?TEST?MAIN. . . C SEG 0003H REL=UNIT MAIN . . . . . . . N NUMB ----- TEST . . . . . . . C ADDR 0000H R SEG=?PR?TEST?MAIN REGISTER BANK(S) USED: 0 ASSEMBLY COMPLETE. 0 WARNING(S), 0 ERROR(S)
