I accidentally hit a button on the mouse while moving it across uVision's window. Now the default docking view where the file/regs/book is only the left, content of source file displays on the right, build/output at the bottom and the borders of these three 'windows' are relative to each other, is gone and I can't seem to get it back. uVision manual has nothing to say about the default docking view. Currently, my view shows either the source 'window' is under the 'file/regs/book' window and this latter window is floating annoyingly. I tried bring up the 'docking' menu, workbook mode, etc. but just can't get it back. Has anyone any idea? Thanks
Use REGEDIT and delete the key HKEY_CURRENT_USER\Software\Keil\uVision2\BSTAT2 and HKEY_CURRENT_USER\Software\Keil\uVision2\DSTAT2 You need to delete all sub-keys. uVision2 will then restore the default view.
Got it! Thanks
