Hi, I would like to use the IAP feature for firmware upgrade in future for bug fixs. But how do I organise my code such that I have a portion "bootloader" that is fixed, and the rest of the code are upgradeable ?? I have tried using the linker option to set my bootloader function at address 0x1000, and the rest of my functions at 0x2000 onwards. But I check the .hex file, what happen is when I changed something in the main body function, the 0x1000 address code also changed. How should I go about it in implementing a "bootloader" section and upgradeable portion of code??? Thank You !! Jerry Yeo
Why do you look into .hex file? The proper place to check where the linker puts every segment is the .m51 file. Regards.
But how do I organise my code such that I have a portion "bootloader" that is fixed, and the rest of the code are upgradeable ?? WHY, oh why do you muck with this. There is ready made software (FlashMagic) free from http://www.esacademy.com that uses a bootloader that is already in the chip Is it NIH syndrome? Erik
"WHY, oh why do you muck with this" Maybe circumstances preclude the use of 3rd party software?
Maybe circumstances preclude the use of 3rd party software? 1) what circumstances would that be? 2) using software made by/for the chip manufacturer is not quite the same as "using 3rd party software". Was it so, the use of Keil would be precludes as well. Erik
"1) what circumstances would that be?" Field upgrades, for instance. The customer cannot be exposed to anything 'technical'. "2) using software made by/for the chip manufacturer is not quite the same as "using 3rd party software". Was it so, the use of Keil would be precludes as well." See above.
Field upgrades, for instance. The customer cannot be exposed to anything 'technical'. I deliver FlashMagic "packed" into a .bat file with the needed parametres for upgrades, they require NO technical skills. Erik
"I deliver FlashMagic "packed" into a .bat file with the needed parametres for upgrades, they require NO technical skills." I know what feedback I'd get if I did that: 'What's a batch file?' In any case, we have to provide equipment that insulates the user from this sort of nitty gritty. Also, a lot of our stuff connects to the PC via one or more proprietry interfaces or perhaps via a network. There is no possibility whatsoever that someone can just go and hook the thing up to a laptop serial port.
'What's a batch file?' aka a .bat file Of course, you make a nice interface to run it so the windiots do not have a problem. Erik windiot: someone that can not imagine anything that does not have a windows icon, clicking 'start' will not do.
"'What's a batch file?' aka a .bat file" Yes, I do know what a batch file is. My point is that 9 out of 10 customers don't.
Yes, I do know what a batch file is. My point is that 9 out of 10 customers don't. Which is why I "pack" it nicely for the windiots. So, The point is that a "nicely packed" .bat file using FlashMagic requires nothing beyond ordinary windiot operations, so, thus it is proven that there is absolutotally no reason to reinvent the wheel as I stated in an earlier post. It is so darn easy to start reinventing the wheel instead of spending a bit of time to find a way to use the wheel you have. Erik
"So, The point is that a "nicely packed" .bat file using FlashMagic requires nothing beyond ordinary windiot operations, so, thus it is proven that there is absolutotally no reason to reinvent the wheel as I stated in an earlier post." So you still can't see that there are situations where FlashMagic is not a suitable solution?
So you still can't see that there are situations where FlashMagic is not a suitable solution? No, I can't, you show me Erik
I don't know what Stefan does. Personally, I'd be inclined to try your method, but here's an example: My company produces controls that can all be networked together using a "FieldBus" and connected to a central visualization system / PLC, etc. It might be nice if one could simply load a new application for the controls to the visualization system and then have that device "push" the update out to the controllers. Assuming the visualization system isn't based on an x86, FlashMagic will be of little use. Using the bootloader in the chip is still a good idea, but having a custom frontend isn't necessarily a bad idea.
Using the bootloader in the chip is still a good idea, but having a custom frontend isn't necessarily a bad idea. No "bad idea" suggested, just so many reinvent the wheel when they do not immediately see the possibility of using the existing. I think Stefan and the undersigned are in the usual "discussion": should you question the motives of the OP or not. Erik
"No, I can't, you show me" I already have. Re-read my third post in this thread.
