Hi, I've used the following code for onecyle delays :
#pragma asm nop;//;simple delay #pragma endasm
; Stack Space for reentrant functions in the LARGE model. XBPSTACK EQU 1;0 ; set to 1 if large reentrant is used. XBPSTACKTOP EQU 300h;0FFFFH+1; set top of stack to highest location+1.
LCALL ?C0023
Instead of this:
Hi Thanks Jon for your hint. Could you tell me why activating the .SRC generation option results in the error? Is the procedure I've gone through for making my function reentrant correct? Best Regards, A.E.
Could you tell me why activating the .SRC generation option results in the error? Is the procedure I've gone through for making my function reentrant correct? I don't know. I haven't seen the source code and Ihaven't seen the procedure. So, I can't really comment on either. IF you want help with that kind of stuff, maybe you should contact technical support. Jon
