Question to ISD51 with assembler code
I will use the ISD51 also with the assembler. I have written a small program sequence for the ISD_INIT() macro.
$NOMOD51
#include <REG932.H>
EXTRN CODE (__isd_init)
cseg at 0
ljmp main
cseg at 0x100
main:
   mov P2M1, #0
   mov P2M2, #0
   mov BRGR0,#0xF0
   mov BRGR1,#0x02
   mov BRGCON,#0x03
   mov SCON,#0x52
   setb  EA
WAIT_FOR_RI:
            JNB     RI,WAIT_FOR_RI
            MOV     A,SBUF
            XRL     A,#0A5H
            JZ      INIT_ISD
            CLR     RI
            SJMP    WAIT_FOR_RI
INIT_ISD:
      LCALL   __isd_init
go:
   mov P2,#0
   inc P2
   ljmp go
   END
If i build the project with the ISD51.a51 I'll get the following from the BL51:
Build target 'Target 1'
assembling P2inc.a51...
assembling ISD51.A51...
linking...
*** WARNING L1: UNRESOLVED EXTERNAL SYMBOL
    SYMBOL:  ?ISD?CORE
    MODULE:  ISD51.obj (ISD51_CONFIGURATION)
Program Size: data=9.0 xdata=0 code=684
creating hex file from "P2inc"...
"P2inc" - 0 Error(s), 1 Warning(s).
The ISD51 don't work with my program. Can anone help me ?
  • The symbol ?ISD?CORE is defined within the library, C51S.LIB, which is automatically incorporated in your application only if you are using the C51 compiler. You have a couple of choices:
    1) Include an empty C module in your application (i.e. 'VOID.C'). It does not require a single line of code, but this will cause the C compiler to be invoked once, thereby grabbing the needed LIB.
    OR
    2) Manually include the library file in your application. Take a look at
    http://www.keil.com/support/docs/2247.htm
    for additional info.
