CAN & EC++
Hi All,
I am a student from UK doing my dissertation on developing a C++ API for a phytec PC167 tartget board.The micro controller i am using is the C167CS-LM which has two onboard CAN interfaces.
I have problems on converting a existing C program in to EC++ CAN class.My existing C program is working correctly and i have converted all fuctions in to class members. I left the CAN register definitions and CAN object definitions in a header file.
The program compiles and links correctly but seems unable to access correct register values.
I am using ROM starting from 0x0 to ox10000 and RAM 0x10000 with size 0x20000.
I will be grateful to you if you can suggest any clues or tips.
Thank you very much in advance.
