Channel Errors Generation:
To assure error randomness, errors due to the channel are simulated by an LFSR based
random generator. For each frame generated at the transmitter, a 16 bit random number is
generated and the errors are inserted as shown below.
If bit E is set to 1 then locate the byte at the position indicated by the 7 Position Bits, and
XOR the two consecutive bytes at that location by the bit pattern indicated in the field Error
Bits.
The frame, made up of the preamble the length field the data field and the FCS is then
transmitted through the serial port to the other station. The receiving station will then check
first for the preamble, if it receives the correct sequence of bits it will then start reading the
consequent bytes until it has read all the bytes of the data field indicated by the length and the
two-byte FCS. To check for the occurrence of errors, the received frame (data field and FCS)
is divided by the polynomial generator. If the remainder is zero, the frame is then accepted
otherwise an error is reported, by displaying a message on the screen.
Does anybody has some assembly code for this problem?!!!
