Simulation of the Synchronous Serial Interface SSC with uvision2 and the XC161CJ
Can somebody tell me how I can simulate the SSC unit of the XC161 with Keil uvision2? Because the software debugger from uvision2 got the peripheral window of both SSC units. The XC161 provides two SSC units (SSC0, SSC1) and the idea is to send data from SSC0 to SSC1 for testing this feature. But there is no physical conection between the ports to be used. Somebody told me to use an *.ini File and include it as initalisation File for debugging, but I don't know what program I have to write or how it should look like.
I want to send a 16-Bit word from SSC0 to SSC1 in half duplex mode with a baudrate of 20Mbit/s. Should I set a breakpoint on every enable event of the SSC Controlregister and copy the contents of the Transmitbuffer to the Receivebuffer or can I simulate the real behavior of this Serial Interface in any way? What about the clock who shifts the shiftregister contents --> must I programm a clock in the *.ini File? I hope somebody can help me
  • For simulation access to the SSCs there are 3 VTREGs for each:
    SSCxIN (contains data coming out of the MCU)
    SSCxOUT (contains data coming into the MCU)
    SSCxCLK (contains the clock rate)
    x specifies 0 or 1 for SSC0 or SSC1.
    You should be able to write something similar to the following signal functions to connect the SSCs. Note that this is not tested, it's just an idea of how to do it.
    signal void SCC0toSSC1 (void) {
      while (1) {
        wwatch(SSC0OUT);    // wait for output on SSC0
        SSC1IN = SSC0OUT;   // copy to SSC1
    signal void SCC1toSSC0 (void) {
      while (1) {
        wwatch(SSC1OUT);    // wait for output on SSC1
        SSC0IN = SSC1OUT;   // copy to SSC0
    Jon
  • Thank for your reply Jon.
    I think your tip will help me but I've got insufficient information about using the VTREGs. Do you have any documents about the VTREGs because I've never worked with them. I know the meaning of the VTREGs but I don't know how to use them.
    Another question is in which way I can use the Serial Window for my Problem. I also don't know how to use and show something in it.
