How can I use putchar while I have to handle incomming bytes
Hi, I have a serial ISR that reads and interprets incomming data but also I have to put data to serial port. the problem is putchar needs TI to be set and TI triggers serial interrupt. what is the usual solution in such situation. well I can reset ES to 0 just before putchar and set it to 1 after that but then I may loose some data???
thank you very much
