24 bit address in 16 bit processor
Please do not say 'paging' I can not handle the overhead for all the other stuff that fit nicely within 64k.
I have a 2Mbyte flash that occasionally is accessed and the time here is not critical (the system pauses) as opposed to other processes that use only RAM.
Is there an elegant way to access structures in that 24 bit address space or does it have to be bent folded and mutilated to access?
Currently all addresses are specified with an 8 bit 'page' and a 16 bit 'address' and processed as such. I could gain some readability by having the whole in a long.
Also this method require data to be stored so no structure cross a page boundary and that limitation is a nuisance.
  • Why not create read and write functions that use a long address and read/write data from a buffer. For example:
    void read (
      void *buffer,
      unsigned long address,
      unsigned long size);
    void write (
      void *buffer,
    where buffer is a pointer to the 'local' data buffer, address is the physical address in the FLASH, and size is the number of bytes to read or write.
    Jon
  • Another method is to use the far memory type of the C51/LX51. The memory access routines can be adapted in the XBANKING.A51 (or LX51BANK.A51) file. In this way you can may simply define the variables using far (for RAM) or const far (for ROM).
    Configuration examples are in the folder
    Keil\C51\Examples\FarMemory.
  • Jon,
    That is basic, the question is to make the compiler process a structure offset.
    e.g. accessing the last entry in a struct at 5fff0 that is 42 bytes long.
    Will that work WITHOUT invoking the baking overhead?
  • Will that work WITHOUT invoking the baking overhead?
    What banking overhead?
    The overhead for code banking consists of an extra byte that controls the upper bits of your data address. See XBANKING.A51. Note that this mechanism is independent of that for code banking in L51_BANK.A51.
    A far pointer takes three bytes, just like a generic pointer. There's a little more overhead there compared to a 16-bit pointer, of course. If you're already using generic pointers, then "far" costs nothing extra. XBANKING.A51 has the implementation for the various library routines that access memory through far pointers. Just customize the macros in there to access your paging hardware and link it in.
  • What banking overhead?
    The extra byte does not worry me, it is the "switch the bank register" for each and every external memory access in the code part with speed requirement that only use the RAM.
  • You may optimize XBANKING.A51 yourself to come up with a better solution. If you have found something better (which is thread-safe and works in all circumstances) please send your suggestion to:
    support.intl@keil.com.
  • OK clarification
    99.9% of the time 'flash does not exist' and time is EXTREMELY critical.
    then rarely a routine is called (sketched here)
    U8 ReadFlash( U32 address)
    U8 byte;
      P4 = ( address >> 16) & 0xff
      SWITCH_IO_TO_FLASH
      byte = *(address &0xffff)
      SWITCH_IO_TO_RAM
      return (byte)
    This works as a champ EXCEPT in a case like this
    data = ReadFlash (structx.offsety)
    where the sum of structure address and offset cross a 64k boundary.
    So what do I want?
    A method where the structure address and offset when directed to a long calculates correct, nothing else.
  • I'm not quite sure I understand the problem.
    ReadFlash (&structx.offsety)
    should only pass in one value, which already combines the structure address + offset. And since the routine only reads one byte, that one byte can't cross a boundary. If you were reading a longer word, then you'll have to change the bank register mid-stream. If you're passing in the address and offset seperately, then you'll just have to add them before taking the address apart.
    If you use far pointers only for your flash addresses, and explicitly declare others as xdata*, then the compiler should only call the XBANKING routines for the far pointers, which is to say the flash accesses. Other, 16-bit, accesses would be performed as normal.
    The library routines seem to compare favorably to the example code with the shifts and masks, even with the bank overhead.
    LOAD_BANK	MACRO SaveAcc
    LOCAL lab
    		MOV	DPL,R1
    		MOV	DPH,R2
    		MOV	?C?XPAGE1SFR,R3
    		DEC	?C?XPAGE1SFR
    		ANL	?C?XPAGE1SFR,#07FH
    		CJNE	R3,#80H,lab		; test high bit of R3 to set carry
    lab:
    		ENDM
    RESTORE_BANK	MACRO SaveAcc
    		MOV	?C?XPAGE1SFR,#?C?XPAGE1RST ; Reset Page Register
    		ENDM
    ; CLDXPTR: Load   BYTE in A             via Address given in R1/R2/R3
    ; Registers which can be used without saving:  DPTR, CY, A
    ?C?CLDXPTR:
    		LOAD_BANK
            JNC	CLDCODE
    		MOVX	A,@DPTR
    		JMP CLDDONE
    CLDCODE:
    		CLR	A
    		MOVC	A,@A+DPTR
    CLDDONE:
    		RESTORE_BANK 1
    		RET
    If access to code space isn't a possibility, just cut out the JNC to MOVC half of the routine and eliminate the test from the LOAD_BANK macro.
    You could still shave a little time from those routines if you happened to know that you only access one segment at a time and have a series of flash accesses with no intervening xdata accesses.
    void ManualRead4 (U8 far* addr)
        SetBankReg(addr);
        byte1 = *(xdata*)addr++;
        byte2 = *(xdata*)addr++;
        byte3 = *(xdata*)addr++;
        byte4 = *(xdata*)addr++;
        SetBankReg (0);  // sets to default value
        } // ManualRead4
    Instead of a U32, you might consider a union.
    /// provides access to words/bytes of a U32
    typedef union
        U32 u32;
        U8  array[4];
        struct { MultiByte16 lsw; MultiByte16 msw; } words;
        } MultiByte32;
    You get a little better code from accessing MyVar.array[1] than (MyVar.u32 >> 16) & 0xff. The compiler could be better about strength reduction of shifts that are multiples of 8 bits.
  • The code in XBANKING.A51 does exactly what your ReadFlash routine does. But it is build into the compiler, so when you have pointers, you need not to decide whether the address is now a flash address or a RAM address. The overhead is this decision (which are 5-6 CPU cycles).
    Of course you may implement your own way of doing it.
  • And since the routine only reads one byte, that one byte can't cross a boundary.
    No, but the address can
    if the structure is located at fff0 and 20 bytes long, the access of the last 4 entries will be 0000, 0001, 0002 and 0003 with 16 bit calculation.
    I DO NOT want the execution routines since they assume all is 'banked' and when operating in "RAM mode" I can not afford ANY overhead.
    ALL I WANT is a means of the calculation of the effective address in 32 bit mode.
    IF the address of an entry in a structure or array is targeted at a 32 bit entity, the calculation should be 32 bit.
  • I DO NOT want the execution routines since they assume all is 'banked' and when operating in "RAM mode" I can not afford ANY overhead.
    The XBANKING routines do not add any overhead when accessing CODE, DATA, XDATA, IDATA, PDATA, or BIT memory areas variables. They are only invoked when you use far or const far pointers.
    Far memory types are limited to 64K in size and may not cross a 64K boundary. As such, the address calculations for far memory objects are performed using 16-bit arithmetic which reduces code size and increases execution speed. A limitation is that compiler-managed objects may not cross a 64K boundary.
    You can do this using a far pointer with a long typed index but you'll have to do it manually and you'll have to read each byte individually. However, this is only required for those objects that straddle the 64K boundary. And, there are very few of those (only 1 if you're using 128K).
    Jon
  • You can do this using a far pointer with a long typed index but you'll have to do it manually and you'll have to read each byte individually. However, this is only required for those objects that straddle the 64K boundary. And, there are very few of those (only 1 if you're using 128K).
    The problem here is that the data is variable and I do not know which units straddle.
    Anyhow, I think it has now reached the point where I have to go back to the proplr that make tha software that generate the file that I store in flash and say "make a hole in the file so no units straddle 64k" I know it will cost me a a hefty fee, but oh well if nothing else works, pay.
  • The problem here is that the data is variable and I do not know which units straddle.
    Well, that complicates things a bit, but still, couldn't you look at the address and size of the object to determine if it straddles?
    Jon
