I am using an Atmel 80C32X2 using Keil 8051 compiler and LX51 linker. I am using both CODE and RAM banking. The banks are mapped as 32K blocks. I use a lot of data that requires to be held in the code space to allow default values to be loaded into RAM. This data is seldolmly used so I decided to put this is the HCONST data space in a code bank. The trouble is that as soon as I try to access this data the linker considers the file corrupt and generates the L220 error. Any help would be appreciated. The type of access is of the form: t_time[i] = t_time_rtc_def[i]; t_time is xdata, t_time_rtc_def is in code bank (far const char t_time_rtc_def[6]). The linker is defined to put HCONST as follows: HCONST (C:0x048000-C:0x04FFFF)
Are you using the correct Linker? I think you need LX51 - not BL51?
I am using LX51. I have actually resolved the problem, however the solution is not as shown in the user manual. Instead of declaring HCONST (C:0x048000-C:0x04FFFF), I have used HCONST (B03:0x8000-B03:0xFFFF). This is accepted by the linker and works in the target. Thanks for replying.
