Getting L102 when referencing an idata public from a C module.
// We want a routine to examine idata memory. // The user types a two-byte address, followed by cr or lf, // at hyperterminal. // The first byte will be the more sig digit, // the second byte will be the less sig digit. // There is a C file with: extern uchar idata addr; // when msb is received // addr = 0x00-0x0f (after stripping) // when lsb is received // addr = ( 16 x addr ) + stripped lsb // e.g.: // input 0x38, 0x30, 0x0a from uart // becomes 0x80. extern uchar idata * p_idata; // p_idata points to contents of addr // ( 0x80 ) // we want to print the contents of 0x80. void printf_02x ( unsigned char c ); // The snippet to print is: p_idata = ( unsigned char *)addr; // example, p_idata is 0x80 printf_02x( *p_idata ); // printf_02x should print // the contents of idata 0x80. ;; There is an A51 with: PUBLIC addr PUBLIC p_idata addr: DS 2 p_idata: DS 2 ;pointer to idata ;; ;; The linker gives: *** ERROR L102: EXTERNAL ATTRIBUTE MISMATCH SYMBOL: P_IDATA MODULE: app.obj (APP)
I think you probably need to re-read the section on Memory-Specific Pointers in the C51 Manual
