my code :
#include <reg52.h> #include <stdio.h> #define uchar unsigned char void main() { uchar value; unsigned int address; uchar *data_buf; TMOD=0X20; // timer 1 mode 2 TH1=0xFD; // 9600 baud at 11.0592MHz TCON=0x40; // start baud rate clock SCON=0x52; // enable RX,TX address=0x01CF; value=0x66; *data_buf=value; printf("\nAddress %04xH Value : %02x",address,*data_buf); while (1); }
Because %x expects an integer, not a char. Use %bx instead.
I have a question. In your example, where is data_buf pointing? Jon
Thanks Stefan Duncanson and Jon ward I can sole this problem as Stefan Duncanson say Thanks again
"I can sole this problem as Stefan Duncanson say" But your code still has a serious bug: As Jon said, you are using an uninitialised pointer!
Hello I wrote new program here,it correct? #include <reg52.h> #include <stdio.h> #define uchar unsigned char void main() { uchar value,data_in; unsigned int address; uchar *data_buf; TMOD=0X20; // timer 1 mode 2 TH1=0xFD; // 9600 baud at 11.0592MHz TCON=0x40; // start baud rate clock SCON=0x52; // enable RX,TX address=0x01CF; value=0x66; data_buf=&data_in *data_buf=value; printf("\nAddress %04xH Value : %02x",address,*data_buf); while (1); }
SO what is the purpose of the pointer? Why not write straight to data_in?
"it correct?" No, because you still have exactly the same error that Stefan pointed out in the first place!
This purpose for my pointer that I want to use in my function
//=============================================== // read EEPROM 24lc256 // input : address 16-bit, // return : 0 if write error // 1 if write complete and get data 1 byte from *data_buf //=============================================== bit read_EEPROM(unsigned int addr,unsigned char *data_out) { bit err; uchar data_in; err=0; i2c_start (); if (!i2c_write_one_byte(0xA0)) { if (!i2c_write_one_byte(addr>>8)) { if (!i2c_write_one_byte(addr)) { i2c_stop (); i2c_start (); if (!i2c_write_one_byte(0xA1)) { data_in = i2c_read_one_byte(No_ack); // read and send no ack *data_out = data_in; } else err=1; } else err=1; } else err=1; } else err=1; i2c_stop(); return (err); } void main() { unsigned char data_buf[1]; unsigned char value; . . . if (!read_EEPROM(0x1234,&data_in)) { value=data_buf[0]; printf("Read %2bX OK",value); } else printf("Read error"); . . } please help me if it wrong. thanks
