Hi everybody. I need some help with the serial interface. The transmission is giving me no problems, but the reception is hanging my software. In the register S0CON (Serial configuration register) I enable the Baud Rate Generator, select 8 bit asynchronous tramsmission but leave the "Enable Receiver" bit off (because I don't want to receive anything at the moment). Both pins for receive and transmit have bit defined Input, output accordingly. Anyway, when I trasmit there is no problem, but when I turn this "enable receiver" bit on my software hangs. At the beginning I thought it was the Loopback function so I put it away, it was not that, then I thought it was the interrupt function with the trap number so I put this interrupt function as a comment and still crashed. Does anybody have an idea what may be causing the problem? PLEASE HELP! Thanks Ernesto Garcia
hi i have some experience on UART , actually i am working on cygnal microcontrolers , i have implemented UART interrupt concept . could you please send the code so that i can provide some solution, i have one application note on UART interrupt method could you please give your email regards neil
Take a look to: http://www.keil.com/download/docs/intsio.zip.asp. Maybe this code helps you to understand your problem.
Hi, thx both of u. Neil e, I would be interested in your app notes and help or advices you may have. My email address is: ernesto.garcia.gomez@ge.com The SW is not hanging anymore. The problem was in the SFR file provided by infineon. The trap number for the Serial interruption was not the correct one. But I am still having some problems debugging. First of all I tried to use the Loopback function (since the product is far from finished) because I have no other way of testing. Well if I understood correctly all the Loopback function does (quoting directly from the manual) is: "allows the data currently being transmitted to be received simultaneously in the receive buffer". So I guess I won't get a receive interrupt. But anyway, I tried to read the S0RBUF (receive buffer) and still I can't do a thing. Any ideas? Thanks in advance. Ernesto
I intermixed the platforms (C51 vs C166). Take a look to the Getting Started User's Guide, Using On-Chip Peripherals, Serial Interface.
