I'm writing a debug/test function, and I want to store it at 0x00E00000. The problem is that all works fine as long as the test function does not call any external functions. This one is ok: smt_1.c (This is the entire file.) int assertWhatever() { return 100; } Compiles ok. Linker command line, notice the absence of ASSIGN: L166.EXE D:cvs\code\OBJ\smt_1.obj TO D:\cvs\code\OBJ\smt_1 SECTIONS ("?PR?smt_1"%FCODE (0xE00000)) PU NOMAP However, the same procedure, but with an ASSIGN directive (for handling an external reference, see smt_2.c below) compile, link and quietly produce an error in the resulting hex code. I expected the four zeros, shown in brackets below, to read 00E0, but it does not! No warnings or errors are issued. smt_2.h86 :02000004[[0000]]FA ... smt_2.c (This is the entire file.) int assertSomethingElse() { report_failure(__FILE__, __LINE__); return 0; } Compiles ok (but warns that "'report_failure' undefined; assuming 'extern int report_failure()'") Linker command line: L166.EXE D:cvs\code\OBJ\smt_2.obj TO D:\cvs\code\OBJ\smt_2 SECTIONS ("?PR?smt_1"%FCODE (0xE00000)) ASSIGN ( 'report_failure' (03D06CH) ) PU NOMAP Any suggestions why this happens? The manual states that ASSIGN "defines a PUBLIC symbol (symbolname) and assigns it a numeric value (value)", and I want just that - no more, no less...
