how to use monitor51
I want to use monitor51 with Dallas DS5001.
I set the dallas with single 32Kb RAM which I split into 8Kb Program Memory and the rest as data memory.
I set the debug setting so the off-chip code memory will use 0x4000 until 0x4fff and off-chip data memory use 0x6000 until 0x6fff.
The problem is when I start to debug the user program it always show an error message NO CODE MEMORY AT ADDRESS 0x0506
The address is always at 0x0506 even I change all the setting at the debug setting
thank you for the advice
